Automatic transmission - Chassis manual section 23
With a flashing N lamp there are two possibilities of what it could be.
If it flashes at 1Hz, once a second, then it will be either,
Input speed sensor
Output speed sensor
Solenoid valve
Out of phase at shift points
A/T control relay system
I'm fairly sure that it's Limp mode as its flashing.
I was getting error code 22 which was input crank speed sensor error but i swapped that out with a known good one and my FTO went into LIMP mode.
(Flashing N)
I'm not getting any sparks from the sparks but everything else seems to be working fine.
I'm thinking it's a sensor error but have no f**king idea what to do.
It doesn't even give me an error code anymore as the engine light just flashes at a constant rate not displaying any errors (Which i assume means there is none bar the limp mode it is currently in)
If somebody could give me a detailed description of what i need to do to get spark in my motor again. I would appreciate it a lot!..
I miss having a car.
Chris.
