plugs from mivec engine loom
- vipfto
For another member who I have done a mivec conversion for, all is great except the place which supplied him loom chopped off the two plugs from interior part of loom (the two that are where ecu connections are most likely white and grey plugs as cant splice to original gr plugs as more wires) and plug from inlet manifold which should have vacuum line to it.
