The power window fuse of Mrs' Pajero keeps blowing. Could it be faulty switch? How come it works fine for a week or so after I put new fuse in if it's a faulty switch?
Haven't installed anything on the car which would affect wiring. Any idea? :\
Power window fuse keeps blowing
- shadowarrior
- Tightarse
Re: Power window fuse keeps blowing
It will be one of the old skool gremlin powered window systems - and theyre probably pulling some kind of prank, or you've gone and fed them after midnight...
Check your fuse mateshadowarrior wrote:The power window fuse of Mrs' Pajero keeps blowing. Could it be faulty switch? How come it works fine for a week or so after I put new fuse in if it's a faulty switch?
- shadowarrior
- Tightarse
Theres probably a short somewhere or you're using the wrong type of fuse me thinks.
- shadowarrior
- Tightarse
12v 30amps... :\ displayed on the fuse box as well. Finding the short is going to be a PIA. I might look at the switch for any tell tale signs of burnt connectors.
Just put a 50amp fuse in there, she be right lolshadowarrior wrote:12v 30amps... :\ displayed on the fuse box as well. Finding the short is going to be a PIA. I might look at the switch for any tell tale signs of burnt connectors.
if it catches fire just pull it out
- fraz91
- Hair-do
Probably find the window motor is on its way out, and is shorting somewhere inside the motor casing. Will be an intermittent short, as may require a certain bump to get it to work hence the week while it works and then it blows.
