size of hub?
ftosteven
size of hub?
Post by ftosteven »
hi!
Do u guys know the size of hub for fto?
66? 67? 69???????
i know PCD is 114.3 but not sure of hub size...help!^^
cheers..
p.s well...is there anyone who has wheel spacers on ?
i'm talking about the thick ones...like 30~50mm..
ruchi
Post by ruchi »
got a death-wish for your bearings?
MIVEC is My Friend :D
RedlineGX
Post by RedlineGX »
Wow... standard offset on the FTO is 38... add 50mm spacers to that and you are talking 88!! I wouldnt even think the car would want to corner properly with that spacing.... dont go past as most 20mm or you're asking for trouble..
Boris
Post by Boris »
Wheels
PCD 5x114.3
Offset 32mm
Bore Diameter 67mm
ftosteven
Post by ftosteven »
correct me if i'm wrong please...but i've seen so many cars with huge hub kit(spacer with wheel studs on) in japan....like 30~50mm...so, i thought it's alright...even drift cars..they sometimes do have big spacers i reckon....as u know..they drive hard...what u reckon?
ruchi
Post by ruchi »
It all comes down to what you want to achieve.
If you want to change the look of the car, then you will achieve this. But you will do so at the detriment of your wheel bearings and your cornering ability.
The spacers will change the centre of gravity and the wheel will no longer be balanced evenly on the hub. There will be more weight on the outside of the hub and less weight on the inside. This creates an imbalance on the hub, and the uneven weight distribution will cause problems with the bearings.
The spacers will increase the "track" (distance apart of the wheels), which in turn will increase the turning radius of the car, thereby decreasing your cornering ability.
Also, another thing to consider, from memory any track width adjustment over 25mm is illegal.
D-TRAIN
Post by D-TRAIN »
RedlineGX wrote:Wow... standard offset on the FTO is 38... add 50mm spacers to that and you are talking 88!! I wouldnt even think the car would want to corner properly with that spacing.... dont go past as most 20mm or you're asking for trouble..
Actually, 50mm spacers added to a stock hub will make the offset -18!
Wider track means offset number goes down.
Your wheels will be sitting out by then, unless you're planning on some wide bodykit or massively flared guards.
And of course, the legality issue of it all...
From FTO to EVO......
ftosteven
Post by ftosteven »
Thank you guys for your advices..ye...Dtrain. i am currently making the wide bodykit...with big flares...wheels look so ugly with big flares...wheels are sittting too narrow compare to flares..so, i wanted to get spacers.
well..since ruchi said it is going to damage bearings..i have to get spacers on just for the show-off!! :?
D-TRAIN
Post by D-TRAIN »
ftosteven wrote:Thank you guys for your advices..ye...Dtrain. i am currently making the wide bodykit...with big flares...wheels look so ugly with big flares...wheels are sittting too narrow compare to flares..so, i wanted to get spacers.
Well if you can pull-off a JGTC look, go for it!
Make sure you post some pics from the show.
ftosteven
Post by ftosteven »
what if i get the wheels that sit out further from the original guards..
what sort of offset do i need to get to fill up the flared guard?
i made the guard about 50mm wider....so to fill it out....well... how does it work? it is very confusing!!!!!!! :x
if i get +10 offset, it comes out +45?since standard offset is 35mm?
goooooooooooooooooooshhhhhhhhhhh!!!!!!!!
heeeeeeeeellllllllpppppppp!!!
D-TRAIN
Post by D-TRAIN »
ftosteven wrote:what if i get the wheels that sit out further from the original guards..
I reckon you're going to have to do abit of "trial and error". Even the stock rims do sit a little in from the guard (especially the front). The front arch is quite large.
But again as a reminder, the bigger the offset number, the closer the rim is to the hub. And the smaller the offset numberm the further away the rim is from the hub.
So in short, if you want your rims to sit further out, you would want to reduce your offset not increasing it.
