Clutch sound
akuma3
Clutch sound
Post by akuma3 »
Ever since i change my clutch to semi-heavy, everytime i step on it, it makes a sqeeze sound ... any idea on what the clutch is doing? could it be they didn't fitted probably? :(
Quattro
Post by Quattro »
By squeeze do you mean like a squeaking spring??
akuma3
Post by akuma3 »
maybe that
it makes sounds even if i step very slowly or softly, it could be that
what can i do about it?
RichardH
Post by RichardH »
I had that. It was the clutch lever at the gearbox end. Even after a regrease of the little ball and socket joint thingy it still creaked a little. It's gone away with the new clutch, at last! :)
- Rich
akuma3
Post by akuma3 »
in other words what i have to take the whole clutch out to fix it?
RichardH
Post by RichardH »
It got a lot better when I asked the garage to regrease the linkage on the lever. The one coming out of the clutch housing with the little ball on the end.
Just live with it until you replace your clutch... :)
- Rich
M1VEC
clutch
Post by M1VEC »
the spring connected to the pedal inside the car sometimes makes this noise, especially if the car hasn't been driven for a while.
