so after doing a leak down test, the rings are f*cked,
so now i have decided to forge the engine and up the boost
look at the difference between H beam and I beam...which one to go for?...i was thinking I-beam...any thoughts?
What should I go for then if I'm upping compression from 9.5:1 to 12:1? I want a low-rotational mass so it'll rev its tits off, but also strong enough that it won't crap itself at the first sign of my right footBennoz wrote:If you're going for massive boost, I'd go H, but if you're wanting something that'll spin up nice & quick, go I.
