sunroof
Taiwo
sunroof
Post by Taiwo »
where do i get weather strips for sunroof? apparantly it might be the main reason for water leaking in rattling like crazy
"Is that a supra???".
"What's a Mitsubishi FTO?"
Re: sunroof
As far as I know sunroof parts are generally expensive and hard to find. I THINK dstocks had a full one, but that was back in April. Theres a wreck at SuziTECH in Thornleigh - Akys' FTO. I think he had leaky seals though, perhaps. Try PMing dstocks or Akys or both.
Akys
Manual Conversion
Re: sunroof
Post by Akys »
nope. my seals are ok. no leak. only prob with my sunroof is my left rail is not working properly. Need to give it a push everytime i try to close it
Taiwo
Re: sunroof
Post by Taiwo »
Do u still have the sun roof or need the seals. Sounds like that is a big sunroof problem I think u should just sell it n I might know somrone fh ;) at is ibterested
Akys
Manual Conversion
Re: sunroof
Post by Akys »
yes, i still have the sunroof. my car is a wreck now so i have most parts.
Its in sydney thought.
Taiwo
Re: sunroof
Post by Taiwo »
Can I grab it off u. I want the sunroof parts though. Also do u have the thing that goes under the syn roof to block the sun.
Re: sunroof
Have you taken the roof lining out?
Re: sunroof
Akys wrote:nope. my seals are ok. no leak. only prob with my sunroof is my left rail is not working properly. Need to give it a push everytime i try to close it
Ah, alrighty then.
Silver - im 95% sure the roof lining is still there
StewyD32
Re: sunroof
Post by StewyD32 »
If the sunroof is leaking and it seems ok. It may be a blocked A frame Pipe where the water runs of to from the sun roof. ( in between the actual roof and inner lining)
Get a long piece of flexi wire and push it through them.
Taiwo
Re: sunroof
Post by Taiwo »
where do i get the flexi wire from?
StewyD32
Re: sunroof
Post by StewyD32 »
Any wire that is flexable and small enough to get into the A frame hole.
You can use anything as long as it doesn't break and gets stuck in it. A guy over here just used a stick he found in his yard beside his car and sorted it out.
If you strip back the lining you'll see a rubber pipe at each corner of the sunroof for draining excess water. Take them off. Give them a clean to make sure their not blocked and also in the A frame. You won't be able to see into the A frame so just giggle the wire around for a while to break up what's there. Might be just some hardened particles or bits of leafs that got washed down over time.
