r spec mivec controller issue ( need a little help)
gavo's mivec
Post by gavo's mivec »
ok so i have the rspec mivec controller and it was a plug and play harness
the only issue i have is that when i turn the car off then on again it resets its self. and the second issue is that it is reading for a 4 cylender car so the revs are showing higher than they are.
i printed of the info sheet on the controller telling you all the functions but it doesnt seem to change onto the cylender settings.
i can get it to go to the clock,alarm mivec points, rpm limit, stopwatch. anyone any ideas
cheers guys
gavo
Rob Furniss
Re: r spec mivec controller issue ( need a little help)
Post by Rob Furniss »
It's a pain to set, I used to have one.
Mine used to reset if the battery was off but not just after turning the power off.
Some instructions here: http://www.mitsubishi-fto.org/parts/ele ... mvc85x.htm
gavo's mivec
yea thats the instructions i have but when i hold the top left (function button) nothing happens
how did you change it to read 6 cyl?
gavo's mivec
FIXED :-D
Ok if this ever happens to anyone what to do is press loads of buttons rapidly and at some point the option is there haha
Rob Furniss
gavo's mivec wrote:FIXED :-D
Yeah that's how you do it lol
Pushing all the buttons like that :facepalm: I wonder what other things you have changed in doing so.
gavo's mivec
Lol dont worry. Once it was on the bit I wanted I went and set everything up :-)
Working fine now woop woop
