Tachometer not reading properly
Lanthias
Post by Lanthias »
As the title states my Tacho is not reading correctly, and the Revs are completely wrong. When I floor it the revs actually go off the meter, and just spins around. Has anyone else had this problem, and if so how did you fix it?
CRIZM
Re: Tachometer not reading properly
Post by CRIZM »
Lanthias wrote:As the title states my Tacho is not reading correctly, and the Revs are completely wrong. When I floor it the revs actually go off the meter, and just spins around. Has anyone else had this problem, and if so how did you fix it?
I have a taco problem as well, but mine is just dead... I was advised to replace the IFS unit. but I've not heard of the Problem U've run across
