I pressed one out tonight, wasn't hard to do, but I didn't take DIY pics, will do so when I do the other side
Yeah, its the Magna one, but the smaller of the two (39mm dia vs the 42mm) which is also the same as a CC Lancer.
They weren't all that cheap at about 50 bucks each, but thats far & away better than the $460 Mitsubishi want for a whole lower control arm
My car had developed a 'click' on take off, felt like someone flicking the firewall hard they were that bad, not to mention the wandering wheel. Im not surprised though, the car's done 165,xxx kms. 30k odd of that with a turbo motor.
The tie rod end is also a ball joint, the only difference is it isn't pressed into a control arm, it screws onto a steering rack arm.
