Indicator problems
- nikhan
Indicator problems
Ok something is pretty wrong with my indicators when I signal right. It blinks double quick time on the dash as well as the orange indicators at both front and back. One minute its like that and probably some time later it becomes normal again. Sometimes it goes very quick and then goes back to normal 3 seconds later while im waiting at the lights. Could there be a trip somewhere or some other wire causing thid problem??? Only happened when I changed my O2 sensor and tat silly mech opened my gear box to try to reach the connectors for it..but of course I showed him the DIY and he only changed the wires at the bottom. Anyway suspect there might be a link to this. Where should I start looking? Damn this post makes me sound so noob...
- Shhtuart
Re: Indicator problems
bad contact on the steering wheel? Maybe your indicator relay is on the blink
- Supplanter
- BUZZ_QWERTY
That would have been my guess too, had a similar problem when I owned my Nissan NX and I just replaced by indicator bulbs.Supplanter wrote:One of your indicator bulbs is faulty.
- aza013
- NSW Coordinator
Agree^^ a bulb has blown or on it's way out.BUZZ_QWERTY wrote:That would have been my guess too, had a similar problem when I owned my Nissan NX and I just replaced by indicator bulbs.Supplanter wrote:One of your indicator bulbs is faulty.
- nikhan
hmmm...problem has somehow gone away. So im gonna leave it as that first. But funny thing before was I tried the hazard lights to test. Hazard lights were at an ok speed but when I indicated left problem arose again. Funny...lolz
- rock_it
As above.. A bulb will blow soon... That is the car warning you, before it actually happens..nikhan wrote:hmmm...problem has somehow gone away. So im gonna leave it as that first. But funny thing before was I tried the hazard lights to test. Hazard lights were at an ok speed but when I indicated left problem arose again. Funny...lolz
Look at your taillight bulbs, i know the contacts get a little rusty and ive had problems similiar, i just sandpapered the bulbs and the holders and it worked a treat.
- nikhan
Ok the car has just came back from the panel beater but my left and right indicators wun work. But if u on the hazard lights all is ok. Just the indicators and the light does not come up at the dash either. Guy sows that it was working before but the suddenly stopped working when later. Any ideas?
- Shhtuart
Theyre on a circuit, hazards will flash at the same speed regardless, you have a blown bulb.
- nikhan
Well found out the problem after muckin ard the fuses. One has blown and one of the indicator was on its way out as well. Apparently the panelbeater blew the fuse while reconnect all my indicators and stuff... ppfft and I had to be the one to source out the problem and fix it. Oh well...at least I have got my car back. The factory T's look sweet as man...but I because its a bit lower I cant get into my driveway. LOLZ
