I'm fitting a 6 point battery kill swtich.
and 1 of the connection's goes to kill the ignition coils.
But what do i do for the ignition coils as the car has 3 output's A, B, & C. Do I cut them all or just 1 of them?
Hi mate, I figured I'd post this as a DIY for everyone to easily find, see link; viewtopic.php?f=10&t=24663
So essentially you don't touch your ECU wiring, this wires into your ignition switch. Other than rewiring your battery and starter motor to go through this switch, you only actually cut 1 wire, the ignition switch wire number 3. See link for full instructions
