Brake Pad Query
-Nighthawk-
Brake Pad Query
Post by -Nighthawk- »
Hey guys,
just received this in the mail today:
I was just wondering, how come there is only 1 clip on the set of pads? Is this normal, if so which side would it go on? (these are for the front set of brakes)
Thanks
Re: Brake Pad Query
They are not a full set :? .
It looks like a mixed box, there should be two of each not one and three.
Re: Brake Pad Query
So you're the one that paid $165 bucks for these from eBay? LOL
Doesnt really matter.. so long as your calipers are both in good working condition, they should wear evenly & the indicator will work no matter what side its on.
-Nighthawk-
Re: Brake Pad Query
haha no I got these for $90 delivered (they are for the GR).
So should I ask for a refund (have to wait 2 weeks for delivery) or just pull the indicator off? I'm not sure on the condition of my calipers, but these will be fitted to new brake discs as well.
Re: Brake Pad Query
They are the same pad, simply 1 does not have the 'whistle' on it.
They will suffice.
But yes, as Aza said, you have 3 of 1 pad.
Didn't GR have single pot fronts?
-Nighthawk-
Re: Brake Pad Query
Ok thanks I might leave it on then.
The GR has a single brake piston
Re: Brake Pad Query
-Nighthawk- wrote:The GR has a single brake piston
ummmmmmmm
I could be wrong, don't think I am, but... aren't those brake pads for twin pots?
Re: Brake Pad Query
ummmmmmmm
I was thinking the same thing.
Re: Brake Pad Query
well, Just searched over the camskill website, and surely enough, with the pictures provided the GR has a split down the middle.
Difference being the backing plate, odd.
http://www.camskill.co.uk/m3b0s535p0/Mi ... Brake_Pads
Seems kind of odd, never come across a single pot with a split pad.
Re: Brake Pad Query
The fronts have the split, EBC says it helps to dissipate the brake dust better.
And I'm 80% sure mine had the same thing, only one of them had the metal clip but they do nothing anyway, the caliper holds them tightly in place and the bracket stops them from going anywhere.
Re: Brake Pad Query
Also, the GPX/GPvR ones are way bigger in size.
Re: Brake Pad Query
3rd post lol. Micheal if you need a hand in putting them in let me know, I'm pro at everything brake related now, just rebuilt my calipers and installed the HEL brake lines 8)
-Nighthawk-
Re: Brake Pad Query
haha that would be great thanks, just to make sure I don't screw anything up.
I won't be installing these for another 3 weeks however
Re: Brake Pad Query
-Nighthawk- wrote:haha that would be great thanks, just to make sure I don't screw anything up.
Easy :lol:
Just let me know and we'll make a day of it.
Re: Brake Pad Query
Shhtuart wrote:The fronts have the split, EBC says it helps to dissipate the brake dust better.
And I'm 80% sure mine had the same thing, only one of them had the metal clip but they do nothing anyway.
Fair enough about the split.
The clip is a 'whistle', low pad indicator.
Re: Brake Pad Query
My understanding is that the indicators sit under the pad compound at a certain depth that when low enough are revealed creating that screeching sound.
I though that clip worked as a guide to slide it into the caliper bracket?
Re: Brake Pad Query
There's different types.
In these pads case, that clip is the whistle that creates the sound when the pad is low.
Would take a picture of the set I have behind me, but too much effort. lol
It rides just long enough that when there is about 2mm left it will make contact.
-Nighthawk-
Re: Brake Pad Query
Just got an e-mail back from the guy on Ebay, this clears it up:
Thanks for the e-mail. The EBC DP3830C are only supplied with one wear sensor pad, as this is the way EBC sell these pads. There are a few reasons for this, the first being that the car should only require 1, as the pads should wear the same on all 4 pads (if this doesn't happen then the car has a different problem with it). The other reason is because on Japanese models, some are fitted with 1, some with 2 and some with 4, and it can differ despite having the same age car, model, engine size etc etc.
Re: Brake Pad Query
^^ :lol: not that it really matters, but what a load of BS :lol:
Re: Brake Pad Query
Shane001 wrote:^^ :lol: not that it really matters, but what a load of BS :lol:
2nd.
