Hi all
Hi all
hello newbie here on this forum,
i have a serious problem that i beleive you guys can help if not im lost,
my car has stopped going into reverse and 5th unless i raise a piece of plastic that is under the selector that comes out of my gearbox, its a white piece of plastic that curves have way up the selector and sits on a dowel pin,
is anyone able to help at all in where to get this part or even what it is called.
thanks
thanks
Re: Hi all
Firstly, welcomne to the club.
This link may help you explain a bit better. Its the breakdown of the manual shifter:
http://www.completefto.com.au/modules/p ... sp?bid=185
Re: Hi all
hi this is what mitsi tried to sell me as a replacement,
but it aint this piece, on the selector itself is a white block that stops the selectors from moving out of place.
it sits on the selector lever.
i have image of where it sits
Uploaded with ImageShack.us
and the actual piece
and the piece on the box itself
Re: Hi all
Get you get us a picture of the offending part?
Oh & WTTC
Oh & WTTC
Re: Hi all
OK, now were getting closer. Itll be on this pic. Give us the number associated with the bit you want:
http://www.completefto.com.au/modules/p ... sp?bid=184
Re: Hi all
im thinking its part 23241 but would need pick of it.
im currently looking around see if i can find one though
Re: Hi all
OK, that is called:
MD749352 - Shoe, M/T Select Lever
There are actually 2 part numbers for this (one is for an early model FTO). As I dont know which one yours is, cant give you a definite.
Re: Hi all
OK, I think thats the one I listed. If you can PM me your chassis number, I can confirm (DE3AXXXXXXX). Itll be on the firewall behind the engine.
