Recommend a mechanic for FTO in Perth
crimson236
Post by crimson236 »
Hi guys, I've just gotten my FTO. My mechanic said it'll cost nearly 2k to change the brakes, alternator and timing belt. Could anyone recommend me a cheaper, but still decent alternative? Thanks
MH999
Post by MH999 »
Auswa auto engineering 18 boag plce morley. Not sure what unit number but hes on the end on the right. Hes done a couple of ftos and his prices are very reasonable and i highly reccomend him.
mr-charisma
Post by mr-charisma »
Grab a quote from RPW .. pretty sure they've got a workshop & are familiar with FTO's..
www.rpw.com.au
MH999
Post by MH999 »
I dont think rpw do car servicing anymore they just sell there parts.2k to do all those things is pretty cheap IMO.
mr-charisma
MH999 wrote:I dont think rpw do car servicing anymore they just sell there parts.2k to do all those things is pretty cheap IMO.
Sounded like they were working on a car when I called the other day..
only one way to know 4 sure..
2k sounds about right for what you wan't done.
crimson236
I only got the car for 6.5. LOL 2k is like 30% of the car. Owell guess it was too gd of a bargain. Thanks guys.
mr-charisma
payaya wrote:2k sounds about right for what you wan't done.
crimson236 wrote:I only got the car for 6.5. LOL 2k is like 30% of the car. Owell guess it was too gd of a bargain. Thanks guys.
If you're getting the timing belt done, you should be getting a few other things done as well while they have the engine rocked forward, like;
Water pump, Engine seals, replace any worn / damaged pulleys (normally aircon pulley by that time)& even just get the tappets done as well if they're starting to tick
Also, if you have no service history on the car, then you should also get them to check over all the fluid levels & condition etc - even replacing brake fluid, transmission oil, engine oil coolant etc in the one major service is a good idea cause then you'll know when they've all been done last..
I guess now you're realising why the car was only 6.5k ;)
Be prepared to have to overhaul the suspension bushes / springs & or shocks at some point in the future as well if that hasn't already been done (about 1500)
crimson236
Sounds like there's quite a lot of work to be done.. I'll prob do the alternator, brakes and servicing first. Budget constraints. Haha will see how it goes from there. :D
mr-charisma
crimson236 wrote:Sounds like there's quite a lot of work to be done.. I'll prob do the alternator, brakes and servicing first. Budget constraints. Haha will see how it goes from there. :D
if your timing belt is damaged, then it would be top priority - you really don't want it snapping while you're driving or engine re-build will be the least of your worries..
crimson236
How do u tell if the timing belt requires changing? I've been told the belt was changed at around 80-100k. It's around 142k now.
mr-charisma
crimson236 wrote:How do you tell if the timing belt requires changing? I've been told the belt was changed at around 80-100k. It's around 142k now.
if it's worn / damaged
didn't the mechanic tell you it needed to be done?
crimson236
He said there's no date on the belt, but after I told him that the previous owner serviced it at 80-100k, he said I could go without changing it for abit longer.
chausta
Post by chausta »
where are you getting the alternator done? Mine needs fixing too, since mivec doesnt work.
crimson236
Re: Recommend a mechanic for FTO in Perth
It's still with my usual mechanic. So far he has repaired the brakes and did a service for me. The others haven't gotten back to me with a quote for it yet. Prob get him to do the alternator as well if there's still no news. I'll let u know when it's done :D
crimson236
Finally got it done. Did it at The Motor Shop in Willeton. Repairs cost abt 1k for brakes, service n alternator.
