Coilover/Brakes Installation
AMACHA
Post by AMACHA »
Hey guys quick quesiton....
How hard is it to install coilovers i jsut purchased a set of JIC coilovers and i want to do it myself....anyone give me a brief rundown? Also anyone know where i can get cheap rotors and pads i want to do the breaks at the same time!......
If both pads and discs are brand new is it simply just a bolt off bolt on job...
installing them is piss easy, just make sure you get wheel alignment afterwards.
I think bennoz has a DIY in the suspension thread and if not let me know and I'll walk you through it.
AMACHA
Post by AMACHA »
I8A4RE wrote:installing them is piss easy, just make sure you get wheel alignment afterwards.
cool cheers mate! any ideas on the breaks?
vipfto
Post by vipfto »
brakes are simple too just remove calipers from hub (no need to remove fluid lines)
remove discs (the caliper holds it in place)
put back as reverse except when it comes to the new pads just push pistons in so it can all fit together
DONT FORGET to pump brake pedal few times before you test and bed them in or no brakes=bad news
DIY for changing struts:
http://www.ftoaustralia.com/modules.php ... pic&t=8761
Brakes are easy as vip mentions. 2 long slide bolts to get the calipers off, another 2 x 14mm bolts to take the caliper braket off the hub. Then the rotor will just come free off the hub.
Assembly is reverse. Just remember thou, if your old pads are worn to buggery, you will need to use multigrips to push the caliper pistons back all the way in. In doing so, you'll push a whole bunch of fluid back up to the master cylinder resevior. Take the cap off it & wrap a rag around it in case it overflows.
Better yet, get a syringe ( you can buy them at bunnings now i think if not a chemist) and suck out the fluid to get to the halway mark. Then as ben says use a set of multi grips or a "g" clamp and compress piston in slowly, keeping an eye on the resivour (sp?)
Geez anybody else remember the old ones that you had to turn whislt pushing with a pair of long nose pliers....f**k me they were a pain the ass.
I8A4RE wrote:Geez anybody else remember the old ones that you had to turn whislt pushing with a pair of long nose pliers....f**k me they were a pain the ass.
Remember?? The rear ones on the FTO you have to do that :lol:
oh really, damm I have to change mine soon... thanks .
FUUUUUUUUCKCKKKKKKKKK
FTEvolution
Post by FTEvolution »
Since we are talking about brakes, how good are the factory calipers on the GR? I wouldn't mind replacing my rotors, but do you also need new calipers of going to a slightly larger rotor?
Smooth and sleepy
FTEvolution wrote:Since we are talking about brakes, how good are the factory calipers on the GR? I wouldn't mind replacing my rotors, but do you also need new calipers of going to a slightly larger rotor?
Shithouse. I really hope you don't have GR calipers on your 6A13 monster do you? :o
I8A4RE wrote:FUUUUUUUUCKCKKKKKKKKK
