Hey guys,
i got some querys about fitting 17inch wheels into my GR, the tyre shop told me to fit 215,45,17s and the wheel is 17x7, but i saw it here that with 17x7, i should fit 215,40,17s. Whats the go?
The tyre shop told me that with 215,40,17 i might get higher revs on the highway??? i'm really confused, because i have bought the rims already but dont know what tyre to fit.
Thanks!
17 inch wheels
- YYgirl
- rxboy
- FTO338
both 215/40 and 215/45 are ok
both will have your speedo reading slightly off but this error is very marginal..
215/40 will have your speedo reading slightly more than actual speed
215/45 will have your speedo reading slightly under actual speed
read bottom of
http://www.myfto.co.uk/fto_performance.htm
you'll see what i mean
read bottom of
- YYgirl
- GPXXX
to a certain extent, the saleperson is right... a 40-series profile tyre will result in a very slightly higher RPM (prob by around 100-150rpms at best) at cruising speeds just very slightly higher because of decreased rolling diameter (as opposed to the 45-series profile)
either way, there's no real noticeable difference on the road whether you choose 45 or 40-series profile.
