Lights not working
-Nighthawk-
Lights not working
Post by -Nighthawk- »
So today when I got home to drive my car I found out my lights no longer work :( Parkers and high beam do just not the main ones. I have tried replacing the fuse and checking the bulbs but it doesn't seem to work.
Any idea how I can fix this?
cheers
vipfto
Post by vipfto »
are they getting power? check that first then back track with wires to find out why
the fuse may be blowing (one under bonnet) which most likely means power wire is earthing out etc
they may not be gettin power at all (break in wire)
by tracing back wires from lights im sure you will find out why
and did you check bulbs or replace them?
