replacing lifters.. anything i should change while im at it?
- incoming
hi guys
finally able to set a set of lifters in from Kempys..
so while im replacing them is there anything else i can/should replace?
- incoming
- incoming
cheers for the info VIP
yeah sorry meant rocker cover..
how much is the gasket gona set me back?
where can i get aftermarket rather OEM..
are iridium honestly that much better then std NGKs?
mind u this isnt a highly modified car.. its my misses dead stocker lol
and spark plug seals???? never heard of this before on any car
- mr-charisma
I think maybe he meant rocker cover gasket / intake manifold gasket..incoming wrote:cheers for the info VIP
mind you this isnt a highly modified car.. its my misses dead stocker lol
- vipfto
rocker gaskets $30-40 each you need 2incoming wrote:cheers for the info VIP
go iridium or platinum they last 3x as long so no need to remove all the crap for rears again
spark plug seals are under the rocker, they tend to leak after time causing miss fire and fouling of plugs
- mk1_escort
ha ha. i was just about to post a topic on the price of rocker cover gaskets until i saw this. thanks vipfto. i'm using my girlfriends car which is an fto. the rockers covers are pissing out oil!!! and yeah. never use plain old ngk plugs on a car where plugs are hard to get to. thank god for iridiums!!!
