GR loom
Private Sales Only
gr_fto_reborn
GR loom
Post by gr_fto_reborn »
I am in need of A GR loom but it needs to have four green plugs that go into the ECU. Any help would be appreciated. postage shouldnt be too much of a problem.
You after the whole loom or just one of the parts. And does it need to be complete or is it going to be hacked up. MAY be able to help.[/i]
    gr_fto_reborn
    I dont need anything behind the dash but i need the whole engine loom complete. It will just make my live a bit easier while doing the 6a13 conversion.
    Why not use the 6A13 loom? Coupled with the 6A13 ECU, you wont have too many problems. Only thing is you need to rewire a few of the engine plugs from male to female (using the GR loom heads.)
    Bennoz wrote:Why not use the 6A13 loom? Coupled with the 6A13 ECU, you wont have too many problems. Only thing is you need to rewire a few of the engine plugs from male to female (using the GR loom heads.)
    Agreed, it much easier way of doing it. In fact im pretty sure all the conversions that i know of have done it that way
    gr_fto_reborn
    Thing is i havent a clue where to start with doing that. I would need a guide for dummies lol. i have been told that the four plug gr loom is a plug and play job.
    ill have a look on the weekend, but I think one or 2 of the wires have been cut on mine unfortunately
