hump along sprk plug chamber wall
- zuihoujueding
Last night, i finally got the mood to change the spark plugs and to my dissapointment, the usual socket to remove sparkplugs for my ex integra and eunos, did not fit in the spark plug chamber of the fto!
theres seems to have a hump along the chamber wall that wont allow the socket down any further. why do mitsu do that????
The original toolkit has a "special" tool for that. Failing that, do what everyone else has done - grind down a socket to fit.
- zuihoujueding
Nah, no handle, just a special tube spanner with a hole to shove a screwdriver through
- I8A4RE
- QLD Coordinator
Re: hump along sprk plug chamber wall
cause they are fu^&ked in the headzuihoujueding wrote: why do mitsu do that????
- zuihoujueding
yes! look nice on the outside but merciless for the DIYians! tried to change the light bulbs for the headlight (hb3), took out the wrong lamp (i went for the outter lamp) and spent 2hrs putting it back....seems like the lamp is held by 2loose plates and they have to put in such a way so it can fit. then my back is too sore to change the HB3.
comeon, mitsu can do better than that. my '88 integra is so much more DIY friendly much easier to work on. i guess thats becos of the FTO fat ass V6 engine! LOL
- vipfto
Bloody hell mate light should only take 2mins to change what made you pull the plate apart its just a simple twist and will come outzuihoujueding wrote:yes! look nice on the outside but merciless for the DIYians! tried to change the light bulbs for the headlight (hb3), took out the wrong lamp (i went for the outter lamp) and spent 2hrs putting it back....seems like the lamp is held by 2loose plates and they have to put in such a way so it can fit. then my back is too sore to change the HB3.![]()
- zuihoujueding
- vipfto
- zuihoujueding
- zuihoujueding
- vipfto
I see now yeah they can be a bitch to do once you have done a few times you will get the hang of it i always thought they had a spring clip then plate which actual bulb sits in?zuihoujueding wrote:H1 is the low beam. theres no twist and turn action there. once the clip is released, two loose round plates (one before the blub and one after the bulb. just came hanging by the lamp cable.
- I8A4RE
- QLD Coordinator
I dont know how many times this has to be said HB4 Low beam HB3 HIgh Beam.zuihoujueding wrote:H1 is the low beam. theres no twist and turn action there. once the clip is released, two loose round plates (one before the blub and one after the bulb. just came hanging by the lamp cable.
If you have any different than that then somewhere along the line someone has molested your lighhts and you should probably get some counselling
- zuihoujueding
