Parts needed
MR2YEN
Parts needed
Post by MR2YEN »
Just got the car serviced yesterday and the pinkslip done. All good, but they found a few major things with needed to be fixed. I had a clicking noise whenever i accelerate and brake. They found that the front engine mounts have gone soft and the rear are broken. They are also a few leaks here and there, with one being where the timing belt is.
I got quoted 1.5k to buy and fit all these parts, with them sourcing the parts from Mitsubishi of course. Just wondering if i could get these parts myself for cheaper? Or if anyone can source these parts for me?
Image[/list]
vipfto
Post by vipfto »
sh*t that not a bad price 8O
but you can get parts cheaper though however when they do crank seals make sure replace water pump and all other seals while in there cut I reckon thats still pretty good
I can get brand new mounts landed in Aus for about $55 and $70 and can get the rocker cover gasket for $27 + postage from Japan. I dare say I can beat all the other prices listed there as well.
    Can get the mounts locally too
    Burson's Auto Parts, $50 each
    Front: EM-4551. Listed as Lancer CG 2.0 4G94 6th/02 onward and mirage CE 1.5lt 4G15 '96-'00
    Rear: EM-3687. Listed as Lancer CC 1.5lt, 1.8lt '92 - '96 and Lancer CE 1.8lt wagon '96-'00
    Made by a company called "Toki auto rubber parts" and sold here through "Boonma Pty LTD"
    MR2YEN
    Post by MR2YEN »
    Cool Dwayne, would you be able to have a look for me if you can get them all cheaper? Like whenever your free, no rush.
    Ben is that the shop in Prestons? DO they send out stock?
    Are the labour cost and all decent for the work thats done? This is at Power Tune Australia in Fairfield
    Get yourself a gates timing belt. I think it was a T987 from memory, but search the forum to confirm that. Should be about $100. I can get a genuine Mitsu one, but the Gates one is probably going to be cheaper. Mind you, might flick that one through just to see what it comes back for.
      MR2YEN
      Post by MR2YEN »
      Would the gates one be in anyway inferior to the genuine one from Mitsubishi? Also how many engines mounts would i need to get for the front and rears?
      Dwayne could you also get the other parts required apart from the timing belt and engine mounts and i will pay for them asap.
      AMACHA
      Post by AMACHA »
      to do all those gaskets and selas it does take 7 hours......i got charged 550 for changing the cam seals crank seals and rocker cover gaskets...
      nikhan
      Post by nikhan »
      Hey are the parts same as for a 95 fto model?
      Same for all FTO's. Difference is in the fornt mount, if you have a tip or manual
      NOTE: the passanger side TOP engine mount (on a tip) is the same for all FTO between 94-97 but changes from 8/97 onwards
