Air filters
Air filters
i thought there was a post on this , but i cant find it
here are two tests on common filters, interesting is the filtration on the first site.
http://www.geocities.com/mikegoodies3/i ... ntest.html
and
http://www.ftooc.org/contents/pages/project/filter.htm
just wondering if anyones used Rush pods or unifilter pods??
Jono
and
Jono
- MattG
The first page says that HKS are the worst, and they can't understand why they sell so well.
You have to remember that conditions in Australia differ greatly from conditions in Japan. Yes the HKS doesn't filter as well as the other ones tested, but then again it has the greatest airflow.
You will see a big difference for filters designed for offroad/rally use compared to road use.
So I guess once again everything is a trade-off ( just for the record I use a K&N on my GR).
M@
M@
The Data Recovery Experts
I have a rush 02 pod on mine at the moment, i took off the hose and everything and clamped it straight onto the engine, more response, but i dunno about overall power, feels similar.. i dont have a cold air intake though, so i lose a bit of potential power thro hot air....
i use to have a HKS green, theyre good, but it ended up being really dirty and wanted to experiment something new... so Rush 02
jono
jono
- GPXXX
i got an Apex'i pod filter on mine... makes a very slight whistle as it sucks air if you stab on the throttle in 3rd at low speeds... kinda like a turbo spooling up in a way... I thought it's suppose to have a throaty induction roar or something?? or is it just the way it was designed??
there is an air filter comparo on the 'net for the FTO, can't remember which site but they said the HKS has the greatest airflow... been thinking about them but they're very expensive though!
- FTO338
well i had the Trust filter that fit into the org air box, it makes a bit of different, but not much. Then I found the Rush 02 for $120 so i put that on instead, from there on i also put a custom heat bracket, & cold air intake. Mate i tell u, did that makes a different,every little bit helps, especially when u having a long drive!
does anyone have any ideas what mine is??
![Image](http://members.ozemail.com.au/~jiwan/DSC01248.JPG)
i think it could be a blitz since the filter looks like fine stainless steel material. then again i compared it to the ones from blitz web site and the ones from those reviews and doesnt quite seem to match.
does someone else make metal filters now?
mine also makes some sucking noise on light throttle, but not like a whistle... its a deeper sound but thanks to the muffler i can hardly hear it.
- GPXXX
any of you guys seen the filter made by Uni filter? www.unifilter.com.au its 165 and currently making air induction would like your thoughts... ![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
any of you guys seen the filter made by Uni filter? www.uniflow.com.au its 165 and currently making air induction would like your thoughts...
sorry try this site www.uniflow.com.au
K& N 57i Kit
does anyone have, or tried the K&N 57i Kit for the FTO?
