Moderators: IMC , Club Staff
APZ-312
Posts: 160 jedwabna poszewka promocja
Post
by APZ-312 » Tue Aug 12, 2008 8:42 pm
hey guys,
jus experience something weird tonight while driving home. The engine light would come on for a bit and then go.
I noticed it would happen mostly during low revs..
Something major I have to look out for or...?
When I got home and left it to idle the light would stay on but when I gave it a bit of rev the light disappears...
Posts: 9594 Joined: Mon Aug 28, 2006 5:00 pm
Post
by I8A4RE » Tue Aug 12, 2008 8:49 pm
Mate it could be a thousand different things. Start with checking the engine codes
Posts: 6422 Joined: Tue Oct 22, 2002 5:00 pm
Post
by Supplanter » Wed Aug 13, 2008 12:05 am
My money is on your alternator.
vipfto
Posts: 4154 Joined: Mon Oct 29, 2007 5:00 pm
Post
by vipfto » Wed Aug 13, 2008 1:27 pm
I reckon ISO will be idling too low
Was it almost stalling?
APZ-312
Posts: 160 Joined: Wed May 11, 2005 5:00 pm
Post
by APZ-312 » Wed Aug 13, 2008 7:54 pm
idling was jus a little below 1000rpm
didn't feel like it was stalling
haven't been able to check the error codes yet..
but u think it could be the alternator?
Happened again today. Took it out to see if it would happen again and yup.. when it's idling or on low revs the light comes on..
Posts: 9089 Joined: Mon Mar 26, 2007 5:00 pm
Post
by aza013 » Wed Aug 13, 2008 8:38 pm
Supplanter wrote: My money is on your alternator.
if it was the alternater the Battery light would come on not engine light but I could be wrong
error codes will tel you what it is any way.
Post
by Supplanter » Wed Aug 13, 2008 9:38 pm
aza013 wrote: Supplanter wrote: My money is on your alternator.
<-- noob
Posts: 23676 Joined: Fri Jan 21, 2005 6:00 pm
Post
by Bennoz » Thu Aug 14, 2008 11:06 am
Self pwning... nice
APZ-312
Post
by APZ-312 » Thu Aug 14, 2008 9:37 pm
ok checked the error code and i got 1 long and 3 short flashes..
so number 13 right?
13 Intake air temperature sensor
What does this mean?
Post
by Bennoz » Fri Aug 15, 2008 10:38 am
You a GR or GPX?
APZ-312
Post
by APZ-312 » Fri Aug 15, 2008 7:39 pm
GPX
APZ-312
Post
by APZ-312 » Sun Aug 17, 2008 9:06 pm
any thoughts guys..?
Post
by aza013 » Sun Aug 17, 2008 9:31 pm
APZ-312 wrote: any thoughts guys..?
I had the same code but have not looked into it yet
APZ-312
Post
by APZ-312 » Mon Aug 18, 2008 8:37 pm
so its ok to jus drive around like that?
Tippin
Posts: 1663 Joined: Wed Feb 27, 2008 6:00 pm
Post
by Tippin » Mon Aug 18, 2008 9:05 pm
yeh it should be ... it just tells the ecu what the air temp is, dont think it will effect performance, although you can get modded sensors which tell the ecu that the air is colder and you get more power (could be a load of sh!t but, just sumthin i read a while back)
APZ-312
Post
by APZ-312 » Tue Aug 19, 2008 7:38 am
hehehe backyard jobs
