Oxygen Sensor
- AMACHA
Oxygen Sensor
Hi all this guy has this item up on ebay he has four of them and itsa genuine mitsubishi one so no cutting or soldering required.
will this fit my fto gpx guys?
http://cgi.ebay.com.au/Mitsubishi-Magna ... dZViewItem
- I8A4RE
- QLD Coordinator
Mate that looks like it will fit straight in and for 38 bucks how can you go wrong. Mine cost me $80 and i had to solder it. Well worth evry cent though went from running about 280-330km on a full tank to 530kms now
- I8A4RE
- QLD Coordinator
Yeah man, i forgot say thank you for that. it worked a treat. Now i have pretty good fuel consumption and i dont nearly die when i start the car in the garage.Bennoz wrote:I8AFRE wrote:Mate that looks like it will fit straight in and for 38 bucks how can you go wrong. Mine cost me $80 and i had to solder it. Well worth evry cent though went from running about 280-330km on a full tank to 530kms now![]()
So it was the sensor.... I could smell you coming a mile away!
What does it smell like rotten eggs or petrol or something else. 450kms is not too bad if you have a heavy foot but getting bad if you drive like a granny. is it auto or manualFTOnick wrote: My car smells really bad but the mechanic said the exhaust is still OK. Is it probably the oxygen sensor? I get about 450 km from a tank
- I8A4RE
- QLD Coordinator
450 is a little on the low side but isnt too bad for a auto. id say keep an eye on it and if it starts getting worse then replace it.
- aza013
- NSW Coordinator
- I8A4RE
- QLD Coordinator
agreed but i think it was bennoz who posted that they charge you atleast $50 for this service. but i dont know i have never checkedaza013 wrote:or you can take it to a mechanic and get them to test the O2 sensor, it will only take about ten mins to do.
450 seems low for a manual. i think some guys on here were saying they were getting round the 650+ mark with a manual.AMACHA wrote: i get 450 a tank max i drive a manual dont push it that much but i do smell fumes in the morning inthe garagei think it running a bit rich.
- AMACHA
so if my garage reaks of fumes petrol fumes in the morning could be the o2 sensor?I8AFRE wrote:agreed but i think it was bennoz who posted that they charge you atleast $50 for this service. but i dont know i have never checkedaza013 wrote:or you can take it to a mechanic and get them to test the O2 sensor, it will only take about ten mins to do.
fingers crossed i see a change when i chuck in the new O2 sensor.
im also changing the spark plug leads sparks and fuel filter hopefully it all makesa difference..
- I8A4RE
- QLD Coordinator
yes it COULD be, changing plugs and leads will also help. Manufacturers recommend that the O2 sensor should be replaced every 90k-120k. Also check the timing if you have a timing light.
- maggsy
- I8A4RE
- QLD Coordinator
As soon as you start being heavy footed fuel consumption goes out the window.maggsy wrote:i get an average of 550 km to a tank, and i have a manual, i think that's about right.
(i like to hit mivec a lot too)
Heres other ppls figures
http://www.ftoaustralia.com/modules.php ... ic&t=13129
- maggsy
i can;t help being a lead foot every now and again. always need a little excitement in life.
obviously i dont take off foot to the floor every set of traffic lights i come to and redline every gear change, i'm just saying that i drive my car the way it was designed to be driven.
i'm sure everyone pushes their car every now and again,
my average driving style woulod see me shifting at about 4.5k revs and i just drive the car like any other person out on the roads.
- I8A4RE
- QLD Coordinator
i dont drive mine much so when i do i drive it hardmaggsy wrote:i can;t help being a lead foot every now and again. always need a little excitement in life.![]()
