fidanza adjustable cam gears
- tintin
dose any 1 no if they fit the 6a12 engine? or dose any 1 have them on all ready?
this is ther spec sheet .
MITSUBISHI
3000GT 91-99 3.0L DOHC 96133_ 4
Diamante 91-96 3.0L DOHC 96133_
Diamante 97-04 3.5L SOHC 96163_
Eclipse 90-94 2.0L Turbo 96199_ 2
Eclipse 95-96 2.0L Turbo (Exhaust Only) 96199_ 1 30
Eclipse 97-99 2.0L Turbo 96199_ 2
Eclipse 95-99 2.0L DOHC Non-Turbo 99420_ 2
Eclipse 00-06 3.0L 96163_
Eclipse 06 3.8L 96163_
Endeavor 04-05 3.8L 96163_
EVO 8 03-05 2.0L 96199_ 2
Galant 99-03 3.0L 96163_
Galant 04-05 3.5L 96163_
Lancer 02-04 2.0L SOHC 96143_
Mirage 97-02 1.8L 2WD 96143_
or the link:
http://www.fidanza.com/files/Fidanza06_07appguide.xls
MITSUBISHI
or the link:
coilovers!! gaurenteed to make boobs bounce
Then no, you dont need them
The only reason one goes & buy vernier adjustable cam gears is if one is putting in hot cams that cannot be completely timed electronically - Ie the cams need to be timed to a position other than Top Dead Centre, like 5 degrees advanced or whatever. So if your not changing cams, its just bling that you cant even see.
- tintin
ahh ok then what aboult lighter cam gears? worth it or not? or every littel helps?Bennoz wrote:Then no, you dont need them
- tintin
- SG
They are a machine finish join to the cam with extremely fine tolerances. Cam timing is pretty critical as you'd know. Out by half a degree could lead to a valve bashing a piston or equivalent. The vernier adjustable type have been round a long time, I've got a set on my mini (although is a timing chain system rather than a dry belt like the FTO.
- payaya
- tintin
not worth the money then?payaya wrote:Doubt it will make a difference! Most of the weight connected to the gear is inside the engine.tintin wrote:cool rpw it is then because i dont no any wher elce that do light weigh cam gears?Bennoz wrote:Well, if you're going for the crank & alternator pulley, and you got the coin, why not!
- Delvance
Hey, every little bit helps. You're doing everything you can to the engine anyways so may as well. See if you can get lightweight pulleys too and install an electric water pump system so you can remove the factory belt driven power sapping water pump. All of that should free up a few horses and more importantly make for a even snappier engine (read: faster response).
- tintin
cheers for thatDelvance wrote:Hey, every little bit helps. You're doing everything you can to the engine anyways so may as well. See if you can get lightweight pulleys too and install an electric water pump system so you can remove the factory belt driven power sapping water pump. All of that should free up a few horses and more importantly make for a even snappier engine (read: faster response).
