my subs cracked the weld in my boot :(
- DRM34R
i recently put two 12inch subs in my boot. i hadnt got round to insulating the boot yet but little did i know the welding between the frame that sits under the boot and the boot itself as come apart in most places!!!
just curious to know if this has happend to anyone??
- DRM34R
- DRM34R
- DRM34R
- DRM34R
- AMACHA
haha in my mates car he recently put two soundstream 12inch T5 taranchla subs 900rms each and i have a monoblock 2000rms i think if i put it up full blast i could shatter glass lol.
- FtoSam
hehee....
I used to run 2x Audiobahn Immortal Series 12s 2000WRMS (Each) Subs off a 4500WRMS Monoblock in the fto back in the days...
was a little loud for me...
And yeah it cracked the welds.. I just put sound deadner through the whole thing... heaps better... dont think i've fixed it to this day...
oh after 150 3inch screws in the box, the weight of the subs still ripped the front off... another 100 in the front piece solved this problem... then the pressure blew the back end out....
Ended up installing steel bracing throught the box...
3x0.5M runs of 0 Ga from the bank of 4 120Ah Deep Cycles to the amp... it could drain them in 10 minutes....
Alternator wouldnt charge them so had to recharge them everynight...
needless to say quickly sold it all (about $9k worth) and bought a single pioneer 300w 12" and a 600w pioneer monoblock...
much nicer sound but not as much bass...
- nvdfto
- ftoohh
- MissxFTO
You dont have to have a sub/s to have a good quality sounding stereo systemnvdfto wrote:dont worry dude its a common thing for boot lids to crack due to the bass come`n from the sub
nothing we can do abt it. unless u want sh*tty sound with no bass then dont get a sub or else boot is gonna go all wonky
Component speakers amped properly with 6x9's give out a crystal quality sound and some nice bass aswell
I have that at the moment and i get a lot of comments asking what i have hiding in the boot.. and its NOTHING!!
[img]http://img291.imageshack.us/img291/923/msf70lz5.jpg[/img]
- FtoSam
Personally i think the best setup is:
Small good quality sub (pioneer 12" are great and really cheap)... only need one small sub..
Good amp to run it.. (anything over 300Wrms is fine)
6x9s in the rear... (doesnt matter.. dont amp them.. under $100 is fine)
Best 6.5" Splits you can afford... (make sure they have an external crossover)
Brands like MBQuartz, Boston Acoustics, etc... Get the Best...
High Quality 2ch Amp for them...
For example, I only spent about $180 on my sub (inc box) and about $400 on its amp (800W Pioneer)...
Spent $75 on my sony 6x9s
Spent $480 on my Kenwood 4ch (bridged to 2ch) Amp for the front speakers
Spent $1099 on my Boston Acoustic Pro Series Front Speakers...
You can see from that where your priorities should lie...
Rear speakers are only for "fill" when you have a sub...
And a nice quality 12" sub will give you some beautiful bass...
Cannot stress enough about good front speakers...
- boarsai
They're not welds, it's glued!
Hence after 10 years or so they don't stick up too well.
Mine went when I put in my amped 6x9's before I went to a sub.
Go down to the hardware store and get some good quality construction grade adhesive like Sikaflex (tubes you use in a caulking gun). You can push the boot skin up a little to give a bit more of a gap to get a good bead inbetween the frame and the skin. Run this around the edges of the frame, just make sure the frames are NOT COMPLETELY SEALED.
Did mine nearly 2 yrs ago, It's taken a hell of a pounding from my 380WRMS sub and still standing up to it...
[img]http://img259.imageshack.us/img259/1613/sigpic2se2.jpg[/img]
