Here are some pics of my car.
First setup…This setup consists of a straight 65mm pipe from the cat splitting in two just after the fuel tank feeding the two straight mufflers. This gave good performance increase and sometimes I also had some minor backfires.
At high RPM the car sounded great. My friends compared the noise to a racer motorbike speeding . The problem was at low rpm when cruising on high gears. The sound was so low pitched that the noise would rattle the entire car and it was very annoying to hear too. So I moved to second setup.
Second setup…. Same as first setup but added a so called twister. This is a small straight muffler which twists the gas so it will reduce the level of noise. This was installed just after the cat. At low rpm noise reduced and even the rattling but is still noticeable. Back fires reduced also. And I didn’t see any lack of performance.
I was told that when the two pipes coming down from the extractors are joint to one pipe (original setup) and then splitting them again to 2 pipes to feed my 2 mufflers, will reduce the performance. So If I am planning to go for a non turbo setup, eventually i'll change the setup again and will feed each muffler with a straight pipe directly from each extractor. So I’ll have two pipes running from front to back. Probably I’ll have to put two ‘twisters’ to reduce the noise levels.
Hope this helps.
