Melted Lightbulb Connecter Thing
DRM34R
Post by DRM34R »
i don't know what its called exactly but the little plug lookin thing the blub goes into has melted for some reason.
atm ive got 2 80W HB4s, too high or no problemo? have orderd 70W as cant get 80W anywhere
one parts place say that fitting goes for $10 and anotha say they go for $200.....whats the go there????????????
[img]http://img440.imageshack.us/img440/4341/untitledom9.jpg[/img]
any car that takes the HB4 globe you should be able to get it to fit the FTO. Also the HB4 stock is 50-55 watts I think so obviously 80 is too high.
DRM34R
Post by DRM34R »
yeah but phillips do 70W so thats what i ordered...im just confused about the part thats melted and the pricin
yeah I know you prob can get 100W, but the FTO wires are not designed for 70W you will keep melting the pulb screw the wires.
kid_dynamite
Post by kid_dynamite »
^^ What he said.
Get an electrician to upgrade your wiring to your lights if you want to use high wattage lights. They draw more power than stock, as a consequence the wires get too hot, and melt. If you increase the diameter of the wiring it can handle more watts and won't melt.
could that also effect my bulbs burning out quickly. cause my bulbs seriously only last like 6-8 months. Im thinking of upgrading to hid kit should this stop the problem (eg does a hid kit contain new wiring?
nvdfto
Post by nvdfto »
stock fto headlight globes are HB4 at 12v 55w
HID are only 35w and is way brighter
i say jus get an HID kit.
with the melted rubber ring jus get the cheapest one. i rkn the place who quoted u 200 bucks is jus try`n to make some money off ya.
im sure all rubber rings do the job.
also try find the fault on how come it melted. it can b heaps of stuff.
Let the tunes decide
.:[Bosch Australia Automotive Department]:.
DRM34R
Post by DRM34R »
its not the ring its the plug the whole lightbulb fitting goes into...as per usual that would be mitsubishi but then again they said i have to get a whole new wiring/light kit...
Ther
Post by Ther »
I had that issue, did you put electrical grease before you put the bulb?.. most likely thats why they fried..
To get a mitsu part they will quote 75 per bulb holder, i ordered for an online shop for 5 buck each and they worked great until i changed them to HID.
The website is http://www.suvlights.com/.
Its in the states but i got the sets i needed for less that 20 bucks australian
DRM34R
Post by DRM34R »
just thought id say i managed to go to greenacre today n got new plugs for $10 n have replaced the 80W with the 50W...all is good now :D
jonowong
Post by jonowong »
do you live near greenacre? i live very close!
DRM34R
Post by DRM34R »
na i live in mount annan. i already knew sydney auto dismantlers cudnt b botherd lookin anywhere closer!!
Ther
Post by Ther »
whats their number?
DRM34R
Post by DRM34R »
97092800....ask for moussa
