Brake Rotor Upgrade Prices
Blk-Jet
Post by Blk-Jet »
Hey all,
Just been in contact with a good friend of mine who distributes Protec/DBA Rotors before they even get to DBA!
I've enquired about prices for the FTO, both the GR and GPX models. From what I know the GPX are twin pot calipers and GR are single at the fronts, but the rears are identical.
You will not find a cheaper price for these anywhere on the net. These are literally trade prices!
Price List:
Mitsubishi FTO GPX
Front
Protec (Standard Rotor) - $115 + GST (Pair)
DBA (Standard Rotor) - $135 + GST (Pair)
DBA (Slotted) - $240 + GST (Pair)
DBA Gold (Slotted & Drilled) - $305 inc GST (Pair) <------ sorry, it's inc not + GST appologies
Rear
Please contact me for prices on Rears
Mitsubishi FTO GR (Single pot front calipers)
Front
Protec (Standard Rotor) - $120 + GST (Pair)
DBA (Standard Rotor) - $180 + GST (Pair)
DBA (Slotted) - $270 + GST (Pair)
DBA Gold (Slotted & X-Drilled) - $305 + GST (pair)
Rear
Please contact me for more deatils on rear rotors
*Free Delivery for all purchases in Melbourne Metro.
**Delivery outside Melbourne Metro add fright charges (Contact for details)
Please Note: Protec Disc are the same as DBA except they are manufactured overseas. DBA are manufactured in Australia.
They also stock :
Brake Pads (Lucas/Bendix/Maxi-Stop/Bosch)
Clutches (Standard to Heavy Duty)
Hydraulics (Brakes etc)
Bearings
Please Contact me at frank_mileto@yahoo.com.au and I can refer you to them if interested.
Cheers
Frank Mileto
GPXXX
Post by GPXXX »
if you could get some prices for the clutch upgrades that'll be great Frank... :)
Adriano
Post by Adriano »
hmmm, seems like it's still cheaper to get it from autospeed.com
[38]-DBA425X: DBA425X Longlife Gold Rotor (pair) $311.70 inc GST (delivered)
can he get it cheaper than this??
G_A_V
Post by G_A_V »
if the gr ones are smaller why are htye more expensive ??
llsf1225
Post by llsf1225 »
Is that possible for a GR use the GPX rotors???
G_A_V
Post by G_A_V »
no unless you buy the gpx calipers, they will bolt on though
are the GPX brakes noticably better than the GR's? I find that the GR brakes seems to fade really quick. I remember trying to slow for a turn when i was doing 140, i bloody missed the turn! :)
FTO338
Post by FTO338 »
payaya wrote:are the GPX brakes noticably better than the GR's? I find that the GR brakes seems to fade really quick. I remember trying to slow for a turn when i was doing 140, i bloody missed the turn! :)
Changing the brakes won't help the fading, my suggestion would be change the brake pads, it will give you a lot more braking power then the rotor!! And of course it would be better if you change both of them.
Depends on what kind of driving you do, as different performance brake pad need different warm up time, so choose wisely. I'm currently running DBA Gold cross/slot (as above) at the front, & Endless brake pads for both front & back.
SilentBobMk2
Re: Brake Rotor Upgrade Prices
Post by SilentBobMk2 »
Blk-Jet wrote:Hey all,
Emailed you last week, but no reply.....
SilentBob
GPXXX
Post by GPXXX »
are the slotted DBA rotors larger than the factory issue? if so will the factory calipers still fit??
