Headlight help please
harry90
Post by harry90 »
as im sure most of u know about the "thing" that comes up over the plastic headlight cover!!! i was wandering how to take it off as mine is getting really bad
there is a thred in the DIY area in regards to this it should take you about 2 hours to do great results to :D
harry90
Post by harry90 »
found it ... thanks a lot... seems like a big job...
no its not that hard give it a go :D
once you get started on it it takes no time at all like I said defor only about 2 hours but use a buffer to polish not hand as you will not be happy with the finish
harry90
Post by harry90 »
buffer using the lamb wool ? seems like good advice... im gonna give it a go tomoro
JOeJOe
Post by JOeJOe »
aza013 wrote:no its not that hard give it a go :D
I second that, mine look shithouse atm lol
I need to get a buffer
BorepYano
Post by BorepYano »
spend the extra time to take the lights off your car first (remove front bar and 2 bolts each light)
so u'll be able to get to the edges of the light :)
