injectors ?? is it worh getting bigger?
tintin
Post by tintin »
im planing on getting a few bitsfrem rpw again at some point would it be worth me getting the 1996 fto injectors as well? and will they help with bhp in any way?
coilovers!! gaurenteed to make boobs bounce :)
what engine and what injectors r in it now?
tintin
Post by tintin »
gpx mivec and it came from a 1994 fto
injectors will be the same
tintin
Post by tintin »
ok cheers :)
have you (or anyone for that matter) looked at the injectors off a Hyundai coupe 2.7 V6????
tintin
Post by tintin »
Please select an item:
Select
Fuel Injector 210cc - Injector () - $45.45
Fuel Injector 240cc - Injector () - $227.27
Fuel Injector 275cc - Injector () - $125.00
Fuel Injector 390cc - Injector () - $195.45
Fuel Injector 450cc - Injector () - $213.64
thats what rpw have to chose from?
will bigger injectors give more hp?
depends on atlot, in theory yes, but then theres things like if the o2 sensor will adjust the air fuel mixture, or whether youll just be blowing un burnt fuel out the exhaust... and eventually burn a hole through the exhaust...
read this.
http://www.ftoaustralia.com//modules.ph ... =injectors
tintin
Post by tintin »
thanks it was just an idear really cheers for your help
