Bulbs for behind clock
Private Sales Only
AJ
Post by AJ »
Need the two bulbs and holders that they sit in from behind the clock. I blew them when changing my dials and have since lost them from my cup holder. Any one got them going spare plase?
Thanks, AJ.
Bulbs
Can help you out there. Have plenty of spares.
cheers dstocks
    AJ
    Post by AJ »
    thanks dstocks. PM sent.
    sublime19
    Sooty!
    Re: Bulbs
    Post by sublime19 »
    cheers dstocks
    all of my bulbs are very dim and i cant see them at night (barely, need my eyes to adjust to the dark to be able to see my speed basically)
    now how can ALL of the bulbs be so "weak" at the same time? and do i have to repalce them all?
    if i do, can u help me out too lol
    dimmer
    Look at your dimmer switch. These are added at compliance time. Likely yours is a bit dodgy or the wrong rating
      khunjeng
      Re: dimmer
      Post by khunjeng »
      dstocks wrote:Look at your dimmer switch. These are added at compliance time. Likely yours is a bit dodgy or the wrong rating
      ya I just took mine off cos it was suspect...
      you need the holders and you can wire in some wedge bulbs to make it brighter...I need to do my climate control unit but just been lazy..
      Easier
      Easier just to replace the dimmer. Go to a wrecker and pick one you like the look of. A Mitsubishi one would be the best bet as it would be more likely to be rated correctly. Better still measure the current in yours and ill check the one in my FTO and see if they are similar (my lights are fine). Take the multimeter to the wreckers with you.
        sublime19
        Sooty!
        Re: dimmer
        Post by sublime19 »
        i dont have a dimmer switch :?
        Seriously i ran my hands over every part of my interior and even into places i couldnt see and couldnt find it.. i dont have a dimmer switch :(
