Gear Box
- kazbah
- National Secretary
Gear Box
As a new owner of an FTO - and loving every minute of it! - could someone please give me a rundown of problems that may be encountered with the triptronic gearbox. I'm not too sure if mine is playing up as it seems to select a half gear while in forth (?)... Its still under warranty so if it is playing up I want to report it now and get them to pay for the repairs..
- MattG
Half gear?
I think I know what you mean if you are referring to the sound of the engine and power. It sounds like it is dropping down a gear, but the gear display on the dash does not show it shift down.
I do not think this is a problem with the gearbox, when the car really shifts down a gear it actually shows it on the dash dsiplay.
What I think you'll find is that the problem you are getting only occurs under slight acceleration up a hill for example. I think that you will notice the sound of the engine sounds a bit deeper, I think this is just when the engine management calls the second camshaft into play.
(or maybe I think too much!)
Oh and note that when you are going down hill with your foot off the accelerator (depending on your speed), the INVECS-II transmission (being the smart little thing it is) will automatically shift down a gear to hold you at the same speed. Even on slight inclines you may find this happen.
M@
M@
The Data Recovery Experts
- kazbah
