Where to find manual gearbox oil plug photos
Des
Post by Des »
Hi noob here could someone advise me where I could find photos of a fto mivec, manual gearbox oil filler and drain plug
Yes I'm doing a oil change in the gearbox but would like to absorb as much information I can find to prevent any stuff ups I have searched much time on Google with no susseces there was one theard on here called diy fto manual gearbox but it seems the images have been deleted or something
any help would be greatly appreciated
I do understand what to do but just unsure which bolts to undo I think there's 3 to lossen I'm unsure where they are iv only Been able to find one of those plugs 1 on the front it was obvious though it had oil written on it
Cheers D
Re: Where to find manual gearbox oil plug photos
The drain would be the lowest plug on the gearbox.
And I believe the fill has OIL written on it... could be wrong though.
Des
Post by Des »
That's what I thought but the plug I found is so low to the bottom it's almost like it's the drain plug the one that says oil
That's why I'm asking anybody if they would be kind enough to share some pictures with me so I understand where, they are supposed to be I have to do the job in the next few days as I have to drop my son off at his mother's which is a 300km drive
Cheers
How close to the bottom is it?
It's not that far up from the bottom of the case as you only put about 2L of oil into them.
From memory it's like 10cm above the bottom of the transmission
Des
Post by Des »
Yes something like that, I'm pretty sure I know which ones to use but like I said It would be awesome if somebody could post a photo but I think this website is dead so I'll just try my luck
You can go through the Mitsubishi manual which should tell you where it is as well:
http://mitsubishi-motors.kiev.ua/Manual ... 08/22B.pdf
Des
Post by Des »
Thanks everyone I did the oil chang all is well but I think there may be up to 100ml too much oil in there after I did the change.
I'm gonna try and get it as perfect as I can but it's too late I have to do a long drive today about 300km
I hope having about 100ml or 150ml is going to be ok dose anyone think that it might be a problem?
Oil should be filled until it starts coming out of the fill plug
