From what I've heard some one tried to get in to the car by forcefully pushing the window down.
Lucky there was no further damage but since this the window don't work as they should.
When the window is pulled all the way up either by holding the button or by auto, once the window reaches the top it bounces back down about an inch because the safety feature kicks in.
Is there a way to reset the window top position or calibrate?
I've adjusted the 2 screws that tells the window the top position but it didn't work.
Anyone know the reset procedure?
Thanks
Drivers side window bouncing back down when pulled up.
- DODO``
Re: Drivers side window bouncing back down when pulled up.
You need to adjust the stoppers behind the door card
- DODO``
Is this 2 12mm bolts?
If so, ive adjusted it in all position with no luck..
silverGPX wrote:You need to adjust the stoppers behind the door card
Yeah also is it pushing through the triangle rubber?
Try and copy measurements off another fto. That's what u did last time
- DODO``
Nop, its not pushing through the rubber..
silverGPX wrote:Yeah also is it pushing through the triangle rubber?
- DODO``
