I did a search and not found anything definite, one thread saying it should weigh 180 - 200kg, anyone know the actual?
Need it for freight quotes.
Cheers,
Rob
6A12 weight?
Re: 6A12 weight?
It doesn't weigh that holy sh*t
I've deadlifted one of these up on my own I reckon it weighs 100-120 max
Re: 6A12 weight?
Well you are the Hulk, maybe you're underestimating.Sahin wrote:It doesn't weigh that holy sh*t
- spetz
Re: 6A12 weight?
It definitely weighs more than 100-120kg.
All alloys I4 engines weigh more than that.
I believe the 4G92 MIVEC was around 150kg or so (not confirmed) so the V6 would be a fair bit more.
- kiz
- SA Coordinator
Re: 6A12 weight?
All I know is they're f**king heavy. But yea would be up at the 100kg+ range
1998 Mitsubishi FTO GPVR AERO
Re: 6A12 weight?
I sent Mitsubishi Motors Australia an enquiry and they sent it across to Japan (apparently) but have now drawn a blank:
Please be advised that unfortunately we are no longer able to provide weight information as Mitsubishi Motors Corporation no longer stock these items and replacement engine weights were not recorded.
MMAL trust the above is of assistance.
Thank you for your enquiry.
Go with 180KG for the freight?
Re: 6A12 weight?
Just under declare it and then they weigh it and charge you the difference that's what I did all the time
Re: 6A12 weight?
Ok good idea, better than over declaring I suppose.Sahin wrote:Just under declare it and then they weigh it and charge you the difference that's what I did all the time
