Rowans GPX Turbo Build
It's early days and we don't know exactly where this build is going yet but it has begun.
Rowan (my Son) has decided to fit a single Turbo to his GPX. He's had a brand new GT35 Turbo (a chinese copy) lying around for a while and decided to get on with it, so we spent some time this weekend moving the battery to the boot and moving the fuel filter and lines out of the way (hopefully enough).
He dropped his car off at the exhaust place this morning for the Turbo pipes to be fabricated.
Aftermarket waste gate hasn't turned up yet but it's on the way.
Emanage blue has been on the car for a while and I should be able to do a basic tune on it till he gets it on the rolling road here, he's already got my AEM UEGO gauge in the car (that reminds me he owes me one!)
Have 275cc injectors ready to go in - they will do for now but he may be looking to go larger later on.
Huge intercooler here already waiting to go in (looks very big to me).
Adjustable FPR is waiting to go on and i'm going to feed the fuel rail in parallel when I fit that for him, just need to get some bits ordered.
If he can get it home from the exhaust place on wednesday with nothing breaking or setting on fire I will be happy and then the real work begins.
The plan is to get it up and running on low-ish boost for now and then upgrade bits later (fuel pump etc).
He has a second stage plan - think's i'm going to decomp the heads, put forged internals in and turn the boost up - yeah right like I know what i'm doing
"If the engine blows we'll just drop another one in", oh the youth of today - too much time and money on their hands!
He's also got more plans for after but i'm sceptical that we can get to that point before he runs out of money or I run out of patience but if we do that will be something unique - probably crazy. I've got my own project to get moving again anyway.
I don't know that much about Turbos and i'm not a mechanic but i've got to help him out.
Will keep you posted - good or bad.
- bjk
- Totes
Re: Rowans GPX Turbo Build
I'm sure all the boosted guys here will be happy to lend your their ear and advice (especially since it's not a p-plater pipe dream but actually already in the works haha).
Re: decomp, Vectose has done this with an engine he refreshed and put into his GPvR. He's can also run E85 though, but has pushed up to 15PSI on stock internals. Tim is on 11 now iirc.
Awesome, good to see another turbo build under way!
Wastegate has arrived so we've just dropped it off at the exhaust place.
Has a 7psi spring apparently - but he's just ordered a 14psi spring for later.
He wasn't expecting it to say Turbosmart on it so not sure what this really is but I suspect it's in disguise particularly based on what he paid for it.
You sure it doesn't say Terbosmart?
- bjk
- Totes
What are you talking about, that's a 100% genuine Turbosmart sticker.Vectose wrote:You sure it doesn't say Terbosmart?
I'm just hoping it's got a genuine 7psi spring in it and not something made up.
Good decision to turbo!
Not so good decision to use China parts.. they like to go bang
GT35 is pretty bloody big, interesting to see how much lag it will have.
Also a big huge f**k-off intercooler is probably going to give you more lag too.
Are you looking to retain mivec function?
Yes I was concerned about lag too, we'll have to see how it goes on that score.Daniel2019 wrote:Good decision to turbo!
It's now looking like he's going to go with HKS 272 profile cams, a Haltech instead of the emanage blue that he's already got installed (not sure which Haltech yet but maybe 750) and 1.2mm
decomp head gasket. Just been speaking to David at RPW on his behalf.
He will most likely use his emanage for now and get used to the car with the turbo on at 7psi while he's saving up for the other bits (cams, haltech etc).
I forgot to ask David but what are the benefits of also going with forged pistons and conrods with what he already has planned?
(I don't want to do the work by the way)
Cams will be good if you can find them.Rob Furniss wrote:Yes I was concerned about lag too, we'll have to see how it goes on that score.
Haltech do a good bit of kit in terms of an ECU, I will be using one for my car too. It's also used by almost every tuner ever so most places are familiar with it.
So the benefits of forged rods and pistons are that you can safely run more boost without bending a rod or putting a hole in a piston, basically. Vectose is running I think 15psi on stock internals, but with E85. On 98 octane safely we can go to around 10psi. Forged internals and E85 would probably see him able to run upwards of 20psi potentially but that's uncharted waters for these motors. E85 is also good to have because you are less likely to melt a piston and it resists knock better than 98 octane so you get both the ability to run more timing and it is safer overall.
Been to check the progress at the exhaust shop, he's just been doing bits in between jobs and he said it's been a pain in the arse so taking a bit longer.
He's almost done though and should get the car back for the weekend, he's made brackets to hold the turbo and he's plumbing in the oil and water lines.
Will get some pics up when the car is back but i'm not expecting it to be running yet, if we can limp home without any drama I will be happy. Still got to fit the injectors, intercooler, do a basic map on the emanage.
- bjk
- Totes
Bet the guy is thinking "Goddamn single turbos on transverse V6s in small engine bays goddamn..."
Yes i'm sure he is thinking something like that, he swears quite a bit just during normal conversation so would have been quite vocal when working on the car.bjk wrote:Bet the guy is thinking "Goddamn single turbos on transverse V6s in small engine bays goddamn..."
- bjk
- Totes
Does Rowan have extractors on his car that the shop is using the 3-1 pipes off the block or doing the whole thing?
Yes he's got extractors so they are just doing an up and down pipe from after they join before the cat I presume, it's going to look like spaghetti.
Does his car have ABS?
If not, tell the exhaust shop to stop complaining as there's plenty of room.
It's an absolute b**ch with the ABS pump in the way.
No ABS on his car, I've got ABS on mine - i'm not adding a turboVectose wrote:Does his car have ABS?
Don't worry, we are all like that... some guys just manage to filter it out when speaking to customers. Others not so muchRob Furniss wrote:Yes i'm sure he is thinking something like that, he swears quite a bit just during normal conversation so would have been quite vocal when working on the car.
Sounds like the guy is fed up doing the job so he's not doing the oil lines now and trailering the car here on Saturday (they were never mentioned when he originally quoted so sort of fair enough).
Going to have to run a feed from the oil pressure sensor location with a T piece if we can get one to fit.
Got his car back today.
We've still got loads left to do but the exhaust is sorted.
Just dropped the sump ready to tap it and run oil lines to the turbo.
Fitted 275CC injectors for now but he will need to go larger later on.
Trying to work out his intercooler pipe run at the moment.
He's ordered a blanket for the Turbo and he's going to need it, we also need to shield his wires as the exhaust is close to everything.
Not much to see yet but here's some pics.
