AC gas keeps on escaping from the seal here..
Need AC expansion valve that will fit 1998 mivec man fto..
as pictured below.
PM me or text/call me on 0420301615
Thanks guys!
Jess
WANTED: A/C expansion valve
- DODO``
Re: WANTED: A/C expansion valve
Or you could just replace the o-rings?
#20centfix
#20centfix
- bjk
- Totes
Don't forget labour man, time is money!Bennoz wrote:Or you could just replace the o-rings?
#20centfix
- DODO``
Checked the o ring and its still leaking at that point.
Sent from my D5833 using Tapatalk
Yes even though it might look okay often it isn't. Also when your putting the pipes on make sure they have pushed in properly before you put the bolt in. The fitting has to be perfect.
Make sure it's all clean in there too.
- DODO``
Cheers
