Jason's GPX
Re: Jason's GPX
It's fibreglass.. Not plastic
- Jasonp
Re: Jason's GPX
Arrived in good condition? Are you serious? As I said before, I sent you a bunch of messages the day I got it about the damage, which you saw and then never responded to.destinationtoby wrote:It arrived in good condition. All pictures provided before hand, it arrived exactly as advertised.dstocks wrote:Actually, not 20 year old parts. This is one of the the prefacelift TS Factory, so no more than a year old (Picture is a bit misleading - the TS is the one behind the Factory Facelift in front). It should not have snapped off the brackets unless mistreated in some way. And besides, if the bar was advertised as being sold in good condition, it should have arrived in good condition. And if it hasnt, both parties should be coming to a negotiated outcome.
The pictures you provided me were obviously not close ups of the mounting brackets, which were all screwed before it was posted. Mezje has pointed this out.
Was advertised as "ready for paint." Most certainly was far far from it.
Attempted to start some sort of negotiation again recently but instead was told to simply get on my knees and suck his dick. Has the maturity of a 12 year old.
- Jasonp
Re: Jason's GPX
Alright so I'm finally about to get my major service done. Not doing the work myself but getting a mechanic to do it all. So far I've got what's listed below. Am I missing anything?
- Timing Belt
- Power Steering Belt
- Alternator Belt
- Rocker Cover Gasket (x2)
- RDA Slotted Rear Rotors
- EBC Red Stuff Rear Break Pads (Front discs and Pads are already done)
- Hydraulic Cambelt Tensioner
- Cambelt Tensioner Pulley
- Cambelt Centre Idler Pulley
- Power Steering Tensioner Pulley
- Alternator Tensioner Pulley
- NGK Iridium spark Plugs (x6)
- Spark Plug Seals (x6)
- Double Half Moon Seal (x2)
- Camshaft Oil Seals (x4)
- Crank Oil Seal Cambelt Side
- Camshaft Core Plugs
- Front Lower Rear Arm Bush
- Front Lower Rear Arm Std
- Engine Mounts
- Water Pump
- Fuel Filter
- Transmission Filter
- Mivec Tappet Adjustments screws + tappet tool + feeler gauges
- Timing Belt
- Alternator Belt
- Engine Mounts
- Water Pump
- Fuel Filter
- mezje
Re: Jason's GPX
You can get most of that from Rob, good list.
Should fix the roof while you are at it!
