Project FTO VR4
- dazjb
Project FTO VR4
Thought I would start a thread with my FTO VR4 which I have been working on for the last 18 months so you can see where im at. Heres a brief rundown ...
First thing acquire a 6A13TT engine ...
New cambelt, pulleys and waterpump ...
A £1.50 worktop clamp does the trick perfectly as a cam-locking tool ...
Move this little puppy to the boot ...
Take this big puppy out of the engine bay ...
Makes sense to respray the engine bay whilst its bare ...
Relocate the brake distribution block ...
And let the new block see its home for the first time ...
Bulkhead pushed back a touch to acommodate the rear turbo ...
The wiring nightmare begins. I kept the GPX loom in there and just added a few bits from the VR4 loom ...
I'm going to try this ghetto method first of stiffening the engine mounts to limit movement. Using Polyurethane Sealant (Tiger Seal was my choice) to 'thoroughly' fill in the voids on the front and rear gearbox mounts. If I need them to be even stiffer I will get nylon jobbies made up instead but this should do the trick ...
- dazjb
Re: Project FTO VR4
Fidanza lightened flywheel with longer EVO flywheel bolts fitted .. with a homemade flywheel locking tool ...
6mm shim made for the drivers side engine mount to lower the engine. Washers have been used at the gearbox end + 4mm milled off the plenum ...
Fuel filter has to be relocated ...
Gear selector cables wrapped to stop from being melted ...
Braided power steering hoses made up ...
Fan butchered and moved over as there is no room at the other side of the rad ...
Boost pipework mocked up and in place ...
Apexi AVCR Boost Controller fitted and mounted into drivers sun visor ...
- dazjb
Re: Project FTO VR4
I cut the front turbo pipe and ground it down so it sits at a sharper angle then had it welded up. This helped with lining up to the ally piping ...
Boost piping welded up and fits a treat ...
The VR4 turbo elbow has been cut, ground down and welded so its sits at a different angle to clear the power steering rack ...
Last two power steering hoses made up and the reservoir moved ...
VR4 Engine cover butchered to fit under the FTO bonnet ...
Boost & Vac connections on the back of the plenum ...
Its all getting a bit tight front and back ...
And the finished article, after lots of metal polishing, painting and hose replacements ...
And the vehicle that has been subject to all this torture ...
I had an Emanage Ultimate installed on top of the VR4 ECU but had too many issues with it so currently fitting a ECUMaster EMU standalone, a big step for me as up until now I have only had experience fitting piggybacks ...
Re: Project FTO VR4
That there is a fantastic job youve done
Re: Project FTO VR4
That engine bay is pretty
Pretty f**k'n awesome
- spetz
Re: Project FTO VR4
Really nice work there.
Why did you drop the engine by 6mm? For clearance?
- dazjb
Re: Project FTO VR4
Cheers folks. Yep, the VR4 engine sits 10mm higher than the FTO so needed to drop it a touch. Clearance was worse for mine due to aftermarket bonnet, that's why i milled down the plenum as well.
Re: Project FTO VR4
f**k yeah looks great.
How did you go about your bay respray? Currently doing it to my car now.
- bjk
- Totes
Re: Project FTO VR4
More shiny than I could ever be bothered making my engine bay! Nice work.
- aza013
- NSW Coordinator
Re: Project FTO VR4
So shiny love it .
- dazjb
Re: Project FTO VR4
Respraying the bay is a doddle with the engine out ... give it a good clean up, key the surface with wet & dry or scotch pad, etc., mask off where you don't want the spray to go then lay down some paintDaniel2019 wrote:How did you go about your bay respray? Currently doing it to my car now.
Re: Project FTO VR4
Looks mint.
Had any problems with welding the cast iron dumps?
Re: Project FTO VR4
Yeah my paint was rattle-canned over so I have to sand all the black paint back to get to original white/primer. Bit of a pain.dazjb wrote:Respraying the bay is a doddle with the engine out ... give it a good clean up, key the surface with wet & dry or scotch pad, etc., mask off where you don't want the spray to go then lay down some paintDaniel2019 wrote:How did you go about your bay respray? Currently doing it to my car now.
But yeah looks awesome, good job.
Re: Project FTO VR4
Angry eyes!!!!
Love it!
Love it!
- dazjb
Re: Project FTO VR4
My mate does the welding for me, him and his old man own an engineering shop. He warmed the two pieces up, welded them together then wrapped them up in a thick blanket and let them cool down really slowly. No cracking and saved him a job not having to make me a custom turbo elbow.Bennoz wrote:Had any problems with welding the cast iron dumps?
Re: Project FTO VR4
Fair enough. I had a new stove pipe manifold made up, didn't want to risk it. Was able to reuse the dumps.dazjb wrote:My mate does the welding for me, him and his old man own an engineering shop. He warmed the two pieces up, welded them together then wrapped them up in a thick blanket and let them cool down really slowly. No cracking and saved him a job not having to make me a custom turbo elbow.Bennoz wrote:Had any problems with welding the cast iron dumps?
And what about the gear linkages? I wrapped mine like that & couldn't even bend them enough to reach the box lol. Had to individually wrap them.
- dazjb
Re: Project FTO VR4
Funny you should mention that, its got a lot harder to engage a couple of the gears since I've wrapped them. Think I'm going to have to unwrap them then redo single as well, going to be a tw@t of a job with the engine, etc. in place.
Re: Project FTO VR4
It sure is
- dazjb
Re: Project FTO VR4
Just to update. Standalone ECU is now installed and car has been tuned. For the first tune running 1bar we managed 271bhp and 313 ft/lb of torque at the hubs .. tuning was done on a hub dyno. Had to seriously richen up the AFR's over 6k RPM to prevent knock which dropped the bhp and torque high up in the rev range. Need to do some digging into this.
For now though I have a quick FTO which as a consequence has an insane amount of torque steer. I've had to drop the boost on the AVCR by 50% in 1st gear and 40% in 2nd gear and still have to feather the throttle to get traction!
- bjk
- Totes
Re: Project FTO VR4
Ah yes, torque steering towards the nearest tree or power pole. Something Bennoz is intimately familiar with.
