Like the title states, I'm looking for side skirts preferably in white with the clips. Willing to pay postage.
PM or call/text Jess on
0420301615
Thanks
WTB: oem factory side skirt in white with clips
- DODO``
Re: WTB: oem factory side skirt in white with clips
The stock sideskirts won't clip into your car, it doesn't have the holes along the length of it.
- DODO``
Double sided tape work? dstocks reckons I have holes on either end (not along the length) that i can make use of.. and mount the rest with double sided tape?Vectose wrote:The stock sideskirts won't clip into your car, it doesn't have the holes along the length of it.
Either that or drill holes which I'd hate to do!
Yup, you will be able to use double sided tape along the length, or sikaflex. And yes, you will have holes at the front, but not at the back.
This^. You wont have any holes in the sill, wasnt sure about the plastic press in clips under the sill. There is normally a plastic press in clip at the front that goes into a circular hole in the sill on all cars with the side skirts, but this is definitely not there on ones without side skirts. The top lip of the side skirt is normally attached with double sided tape anyway, so yes that will work.
I might have the ones off my Version R (which are white). Ill have to check in the shed.
- DODO``
yes please let me know the condition as well.. I will drive down to meet you at Canberra when I get my car on the road. In a meanwhile I will come up with the list of things I might need and if you have things that you can let go I'll take it off of ya.dstocks wrote:This^. You wont have any holes in the sill, wasnt sure about the plastic press in clips under the sill. There is normally a plastic press in clip at the front that goes into a circular hole in the sill on all cars with the side skirts, but this is definitely not there on ones without side skirts. The top lip of the side skirt is normally attached with double sided tape anyway, so yes that will work.
Do you happen to have a pic of it? and how much would you let them go for? cheers as always dstocks
Hey,
Just checked in the shed. I do have a set of stock sideskirts with matching end caps. $60 should cover it. Can get photos if required but will need to wait till Wednesday
- DODO``
Deal!dstocks wrote:Hey,
I'll hopefully be able to make it to bonfire to pick things up. Thanks dstocks and was nice to chat over the phone!
