changing inner cv boot
i am changing the inner cv boots this weekend. does anyone no of a guide?
Re: changing inner cv boot
Don't think I've ever seen a DIY for it, it's not too big a job. You essentially have to remove the entire driveshaft though - and you'll need a pair of circlip plyers to be able to remove the inner coupling, so you can slide the old boot off & slide the new one on.
Take a look through my Galant thread, you will find pictures of me doing this job...
http://ftoaustralia.com/v3/viewtopic.php?f=41&t=28648
thanks guys. ill have alook at your thread phil. will let you know how it all goes.
finished this tonight. ended up just leaving the inner cv joint still in, and removed the bearings/shaft. then just cleaned and re-greased and put the boot on the shaft & assembled. like bennoz said wasn't too bad of a job.
i did a write up on a diy for changing inner cv boot/drive shaft removal.
http://ftoaustralia.com/v3/viewtopic.ph ... 12#p399712
