Selling a brand new caster + anti lift kit. Designed to add 0.5 deg static positive caster to both front wheels while changing the nature of front anti-dive & lift. The low compliance bush also maintain higher dynamic positive castor. By changing the front control arm geometry - the new alloy mounts coupled with the new low compliance polyurethane bushes change front suspension attitude. This leads to superior traction under power including cornering & dramatically reducing understeer & front wheel spin. The additional castor coupled with the new firmer bushes supplied serve to dramatically sharpen initial turn-in response then forcing more consistent alignment angles through the corner due to the reduced bush compliance.
I am to lazy to fit them and have been sitting around at home. Cheapest place on ebay ATM is $80 with free shipping. Selling for $70 with free shipping Australia, Located in Byron Bay NSW.
NEW- Whiteline +.5 caster kit $70
- fto-007
Re: NEW- Whiteline +.5 caster kit $70
These wouldn't fit on your FTO anyway, they're for a pre facelift. Or you can get the brackets from a pre facelift.
Facelift use a different and improved setup, same as the early evo's.
- fto-007
