Hi all,
I have the engine light and gearbox light (N) flashing at about the same rate. Constant and car won't start, turns over and just doesn't start. Any ideas??
I joined pin 1 to pin 4 to get the diagnosis to light up the lights.
Engine light on, gearbox light on
Re: Engine light on, gearbox light on
No codes then (i.e no pauses between flashes) when you have pins 1 and 4 connected or what codes are flashing up?
Rob Furniss wrote:No codes then (i.e no pauses between flashes) when you have pins 1 and 4 connected or what codes are flashing up?
Yes no codes just a flash about the same speed as the N for the gearbox
- Supplanter
Limp mode.
Starter motor has been replaced recently and the battery is charged and on charge...
- Shhtuart
Disconnect the battery and put it in neutral and try starting.
- Shhtuart
That is after you reconnect the battery, of courseShhtuart wrote:Disconnect the battery and put it in neutral and try starting.
