Hi, new to ftos
Hi, new to ftos
Hi I currently own a 1995 Fto mivec. bought it for $800. Drove it home for the weekend and then next day it wouldn't start properly. The car starts but as soon as I let go off the key it dies. Haven't had a chance to take it to mechanics yet. Also have just noticed that my fto doesn't seem to have an air flow meter. The previous owner has used some cheap silicon for the intake and there is no afm. Am i wrong but does the fto use an afm? Ill upload a pic when i get a chance.
Re: Let the rare part out begin :(
Possibly stepper I think for the first problem?
and the Mivec motor has one built in to the manifold.
Re: Hi, new to ftos
Actually, it uses a MAP sensor that is on the firewall instead of a MAF.Technikhaus wrote:Possibly stepper I think for the first problem?
Re: Hi, new to ftos
As soon as you let go of the key, depress the accelerator firmly to the floor to clear it out.
Re: Hi, new to ftos
That's the one, couldn't remember the nameVectose wrote:Actually, it uses a MAP sensor that is on the firewall instead of a MAF.Technikhaus wrote:Possibly stepper I think for the first problem?
Re: Hi, new to ftos
ok thanks, I have tried pressing on the accelerator but it doesn't work. Could you guys please send me a link of what the stepper motor looks like? So the mivec model doesn't have any sort of afm on the intake ? but a map sensor on the firewall?
Re: Hi, new to ftos
Stepper: http://www.cyberspaceautoparts.com.au/c ... Motor.html
Yours may be brown though, and it is located on the throttle body, directly under your intake pipe.
Correct, no MAF on the intake pipe on the MIVEC engine. Instead it uses a MAP sensor. It is located directly behind the intake manifold on the firewall and has a vacuum hose that is connected to the manifold.
Re: Hi, new to ftos
Would the other model ftos stepper motor work? such as one from an fto with a 4g93 or the non mivec v6 from n fto?
Re: Hi, new to ftos
Yes, steppers are all the same
