My front foggies finally arrived off ebay. After install the halos work fine but I can't figure out the wiring from the diagrams for the fog lights. I checked the cabling from the harness. It has wires for blinkers, parkers and fogs. Everything except the foggies work. Fuses are all fine.
Can anyone confirm wire colours for the fog lights? Keeping in mind it has had a facelift and there were no foglights there when I bought it. I hooked up to what looks like Black for ground and Red for + (although it's a faded red?? lol)
Just thought I'd ask on here before I get the multimeter back out again.
Cheers.
Fog Light Wiring
- Nath
- Nath
Re: Fog Light Wiring
Oh forgot to mention, haven't had a real good look at the switch yet either. I don't know if the circuit was good to start with so it's a long list of possibilities I guess.
Parkers work when fog light switch is on.
Your switch will be buggered - common issue. Remove switch, unplug and check for burn/scorch marks on the back of the switch.
- Nath
I suspected the switch, just looked at it. No burn marks at all. Tested with multimeter, all good. I'm a little stumped now.
Might have to do a wire trace. Not looking forward to that. I hate wiring. Stabbed myself twice last night, almost burnt myself with solder too, always having fun.
- Nath
Well you were right, yet again. Turns out you can never trust a simple continuity check. Sure it flows power, just not enough to ignite the parkers. I noticed the contact points on the little sea-saw like actuator inside the fog light switch were pretty corroded so I filed them back a little. Check with ohm meter instead of stupid buzzer for better accuracy and hey presto it all works.dstocks wrote:Your switch will be buggered - common issue. Remove switch, unplug and check for burn/scorch marks on the back of the switch.
Wasted a little time checking wiring but I went with my gut and followed your advice.
Cheers dstocks
- Halos
- 20140222_194740.jpg (103.45 KiB) Viewed 314 times
- Foggies
- 20140222_194708.jpg (114.65 KiB) Viewed 314 times
- shadowarrior
- Tightarse
Where did you grab those foggies from? And what are you using for the small lights the bottom vents?
Looks mint
I wouldn't rely on that switch for long though, most of us have supplemented it by adding a relay in behind it. The switch on its own will burn out.
Looks good!
I always thought about putting little lights in the small holes, I'm guessing they're used as parkers?
- Nath
Little lights are just the parkers, bought the LED ones though.
I got the fog lights off ebay with some help from dstocks.
I have a fused relay ready to put in now that I got the switch working I don't want further issues.
