head unit choice
- Chebus
head unit choice
ok so my touch screen is dying so its time to replace it.
So these are the 3 Ive found so far that i like. But i have no clue really, any suggestions would be awesome! after a 7" touch screen, dont want to have to play with knobs
JVC:
http://www.ebay.com.au/itm/JVC-KW-AV71B ... 58d&_uhb=1
Sony:
http://www.ebay.com.au/itm/SONY-XAV-741 ... 44d&_uhb=1
Kenwood:
http://www.ebay.com.au/itm/KENWOOD-DDX6 ... 44f&_uhb=1
JVC:
Sony:
Kenwood:
Re: head unit choice
7" Android tablet
im with vectose, best thing i have ever done for my car!
what tablets fit?
samsung galaxy tab
- Chebus
does it have a radio tuner? i need my JJJadzski wrote:samsung galaxy tab
also is wiring it up to speakers and such a PITA?
I have a regular single din head unit behind the tab. The tablet plugs into the AUX port on the head unit and I have a IR repeater set up in the air con vent to control the head unit with a remote.
- Chebus
sounds like quite the setup, also kinda expensive, might just stick with the double din and nothing else. much simpler for a scrub like meVectose wrote:I have a regular single din head unit behind the tab. The tablet plugs into the AUX port on the head unit and I have a IR repeater set up in the air con vent to control the head unit with a remote.
i relocated my headunit to the glovebox, i think vectose kept his behind the tablet.
http://ftoaustralia.com/v3/viewtopic.ph ... &start=240
relocating the headunit is easy, just need to extend your harness, buy a antenna extender and the audio cables.
most expensive part is the tablet, i think all up cost me like $300Chebus wrote:sounds like quite the setup, also kinda expensive, might just stick with the double din and nothing else. much simpler for a scrub like meVectose wrote:I have a regular single din head unit behind the tab. The tablet plugs into the AUX port on the head unit and I have a IR repeater set up in the air con vent to control the head unit with a remote.
Tablet was $200 and the head unit I already had. But you can use any cheap head unit. IR repeater is $5
probably cheaper than a new head unit that your were gonna buy.
rough cost list for me!
tablet $200
harness extension $10
antenna extender $10-20
audio cable + female to female connector $20-25
12v to 5v converter $12
long Aux $5-10
tablet $200
long Aux $5-10
Go the kenwood! I have one and it's f**king awesome!
- shadowarrior
- Tightarse
Eonon double dins running android.
- Chebus
eonon:
http://www.ebay.com.au/itm/GE01E-Eonon- ... c82&_uhb=1
looks nice, thanks for the recommendation
- shadowarrior
- Tightarse
Had an eonon as my previous head unit. Tons of feature, lasted good number of years. Build quality is decent as well.
- shadowarrior
- Tightarse
Oh and check eonon's website, they often run good sale deals.
f**k eonon get a kenwood
Eonon is the tightarses double din
