I'm a tosser
- COTY Manual
Re: Hi there guys new to fto :)
Nah I didn't... but thats why it looks higher than mine hahahahaha.
Raise it up a bit, don't you scrape errywherr?
I struggle at 11cm.
I struggle at 11cm.
Daniel2019 wrote:
I struggle at 11cm.
destinationtoby wrote:Daniel2019 wrote:
I struggle at 11cm.
That's what matt said
- COTY Manual
- COTY Manual
If you're smacking your sump on things then it can cause some big problems.
I would raise the car up if I were you...
- COTY Manual
COTY Manual wrote:sump perfectly doesn't look good!
I got a spare if you need one
Is it undinted
- COTY Manual
It's pretty good dan
- COTY Manual
Yeah but only because it's smashed in...COTY Manual wrote:Lol I mean it doesn't scrape anymore after that dent
Dented sump = bad bad bad bad
I'm in Melbourne right now but I'm pretty sure it was alright aye... I don't remember it being dented
- COTY Manual
I'm still runnin with this one. Works great
You'd be better off using a plastic bucket tech screwed into the block lol
How much for the sump?Sahin wrote:You'd be better off using a plastic bucket tech screwed into the block lol
