possible top engine mount goinggg
- Fulltiltorgasm
Been gettin the occasional clunk when going over the occasional bumps, only noticed it after tyres where getting down to 32 psi, put em back up to 36 and just happen to notice the occasional clunk. Springs & shocks done about 60,000 2 years old, so i would image its not a suspension issue, but am taking it to pedders (rip merchants) just to get the 20 somethign points test, just to make sure no issue and elimnate that. im thinking its the top mount as other ones have been replaced recently and its prob orig and looking slighty worn. any other thoughts on what it could be ? also getting very slight vibrations thru car. if it is the top mount are they readily available ? thanks
Re: possible top engine mount goinggg
Sway bar bushes?
- shadowarrior
- Tightarse
Pedders are shitfucks. Do you get the clunk if you drive slowly over say a bump? I have a feeling they are the drop links. Easy to change.
- Fulltiltorgasm
Yeah, doesnt do it every bump, but I did drive over 2 speeds bumps at slow speed and yes small clunk each time. still does occasionally at higher speeds aswell. Yeah pedders are riip merchants just want them to have a look at see if they can pinpoint the clunk for me.
Pedders will tell you everything is stuffed and needs to be replaced and quote you 3k.
- shadowarrior
- Tightarse
And they will also scare you to think that if you take the car out of their shop, it will just break apart in pieces and then implode into a worm hole. Once you are sucked in and agree to the job for $3k, they will open everything in your car....and then tell you they found more stuff broken and it's going to cost you $6k total, if you negotiate, they will bring the price down to $5.5k. After getting everything fixed, if you drive down to another Pedders near you for the 20 point check, they will tell you everything in your suspension is broken again.Vectose wrote:Pedders will tell you everything is stuffed and needs to be replaced and quote you 3k.
True story.
- shadowarrior
- Tightarse
Oh and you can take your wheel off and see if the drop link heads are attached in funny angles to the sway bars...if you can move those heads around with your hand, your drop links are rooted. Pretty common part to go as part of wear and tear.
- Fulltiltorgasm
yeah ive already been pedders once before same story said about 3500 worth of works, i laughed at them and showed my mechanic he also laughed too. if it is a droplink will driving it a couple of days before i can get it to my usual mechanic do much damage ?
- shadowarrior
- Tightarse
naah, should be fine. Btw, you can change drop links yourself...easy as peeing after getting drunk.
I'm sure theres a few jokes in here somewhere..shadowarrior wrote:naah, should be fine. Btw, you can change drop links yourself...easy as peeing after getting drunk.
- shadowarrior
- Tightarse
lol
not gonna get them out of me till am drunk again
- shadowarrior
- Tightarse
Breaker bar, muscle and wd40. Mine were rusted, got them out last week. spray wd40 24hrs before you want to do the work.
f**k WD40, just get a bigger breaker bar
- Fulltiltorgasm
ok so noise was right hand bush goneskis on sway bar, left isnt far behind either, so basically all joints/bushes are getting on aswell, none of these have been replaced in over 100,000 so thats quite legitimate. is it hard to get the sway bar bushes ? also as there is no bush there anymore im guessing its not the best idea to drive it until its replaced?
other thing they said was the bump stops on suspension were smashed all round ? are these a serious asap kind of repair needed ?
http://www.ebay.com.au/itm/Mitsubishi-F ... 1bd&_uhb=1
Sway bar bushes ^
Nope bump stops aren't anything urgent, unless ya doin jumps n sh*t
But if they're smashed to crap, then it might mean shocks are rooted.
Sway bar bushes ^
PHIL069 wrote:Sway bar bushes?
Right againFulltiltorgasm wrote:ok so noise was right hand bush goneskis on sway bar
Your Jedi powers are weakening Sidwarriorshadowarrior wrote:I have a feeling they are the drop links.
- Fulltiltorgasm
destinationtoby wrote:http://www.ebay.com.au/itm/Mitsubishi-F ... 1bd&_uhb=1
Sway bar bushes ^
those bushes are 20mm apparently he said he measured swaybar and mine was 16 or 18mm ?? anyone know why this could be ?
- Fulltiltorgasm
also would there be anyway of getting a hold of the swaybar bushes from a suplier in australia so wont have to wait ?? ze help is appreciated
Go to bursons and order 1 x Super Pro sway bar bush kit Part# SPF1344-16K (16mm) or SPF1344-18K (18mm)
Same bush as a Galant HG, HH and HJ
http://www.superpro.com.au/superpro-par ... 344-_%20_K
